CHANGED BULB, SAME PROBLEM. GREEN LIGHT BLINKS 23 TIMES AND THEN STAYS ON SOLID. THEN TURNS RED AND FLASHES 5 TIMES F0R 19 TIMES BEFORE TURNING OFF. NO PICTURE OR SOUND DURING THIS TIMECHANGED BULB, SAME PROBLEM. GREEN LIGHT BLINKS 23 TIMES AND THEN STAYS ON SOLID. THEN TURNS RED AND FLASHES 5 TIMES F0R 19 TIMES BEFORE TURNING OFF. NO PICTURE OR SOUND DURING THIS TIME
you probably just need to replace the lamp. First thing that goes wrong on these tvs.you probably just need to replace the lamp. First thing that goes wrong
on these tvs.
Problems that do not happen all the time are hard to find--2 things: if set blinks the red light try to count the blinks--usually that is an error code.
Also this set if it does for the most part work should have an error buffer.
With the set turned off and using the Sony remote:
Display
5
Volume down
power
If it has this when it comes on there will be a box in the middle of the screen with several items listed---all must have a zero to the right of them---if one has a number(any number) it means it has detected that error that number of times.
The most common cause of No Picture - Lights Flashing, or Intermittent Picture - Picture Cuts Out in all Sony LCD TVs is bulb failure.
No troubleshooting or replacing parts should be attempted without installing a "known" good bulb. This is not a fault, the mercury in the bulb has been consumed.
Many dollars are spent on parts and service when the only problem is bulb failure.
You can replace the complete Lamp Assembly or the Bare Bulb. DIY or get a serviceman. Here is a link that shows how to change or replace the bulb or lamp in Sony KF50WE610. Sony Lamp, Bulb, Installation Guide
New bulb is just fine. 3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position. Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly. Turn On TV and get vivid picture of Sony. Thanks.
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
on these tvs.
how many red flashes?
how many red flashes before a pause?
