Apple iPhone 3G Logo
Posted on Apr 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The ringer icon keeps appearing on the screen
Anonymous
Level 2:
  • Expert 502 Answers
  • Posted on Jul 10, 2010
Anonymous
Expert
Level 2:
Answers
502
Questions
0
Helped
1434123
Points
774
Sorry but your Ringer switch needs replacement. Take it to the apple store and see if they'll give you a replacement. If they don't there are third party iPhone Repair Services that can fix it for you. There are also free iPhone Repair guide that show you how to fix it yourself.
Jitterbug flip won't ring. I've checked the volume and it's set at maximum What is the Jingle, I've tried both ways, no help. Exasperated, donna
Page 30 of manual at the link shown suggests a way to silence the Jitterbug.
http://www.specsserver.com/CACHE/FREOWQFWSXOG.PDF
Quoting from Page 30:
To adjust the ringer volume:
1.
Be sure the phone is open and on.
2.
Press the
Up/Down
volume button
on the outside of the phone below the
display window. Press each time you want
to advance to the next choice.
These choices will appear on the screen:
- Ringer Volume Ring Max
- Ringer Volume High
- Ringer Volume Med
- Ringer Volume Low
- Ringer Volume Silent
3.
When you're satisfied with the setting,
release the volume button.
Your Jitterbug may ring and vibrate
to alert you to incoming calls. The
ringer and keypad can be silenced
by pressing the volume button
Down
until
"Silent"
appears on the screen. Your
Jitterbug will now only vibrate to alert you
to incoming calls (This can come in handy
at a movie, a library, or any other location
where a ringer may be a distraction.
May 09, 2018 • Cell Phones
HOW DO INCREASE RINGER SOUND
Hi Melvin
Majority of phones... when you are in the PHONE screen , just
Press the "+" button on the upper left side of the Phone. The Ringer screen will appear, superimposed on top of the screen you most recently used. Click the "+" button one time to raise the volume one level. Continue clicking the "+" button to raise the ringer volume higher until its at the maximum level...or however loud you want it.
Apr 28, 2016 • Cell Phones
1helpful
Unmute ringer
I couldn't agree more, but I still maintain that a large, translucent icon should appear on the screen when the Mute button is actuated, regardless of what it does or does not silence. Having to *remember* to look at a tiny orange/no orange marking on the side is unnecessary and silly.
Parts For BMW
My ringer is off. There is an icon on the screen lower right hand corner that says off
Hold down the # key to restore the ringing profile. The icon will no longer be there. Thanks
1helpful
My iphone keeps buzzing and shows an icon of the ringer with a slash thru it it wont actually ring, just vibrates altho the ringer is on
"An icon of the ringer with a slash through it"?....Usually that means that the ringer is OFF.If you're sure that the ringer is in fact ON , then check your profile.If it's in the Silent or Meeting profile, the ringer is switched off by default and it goes to vibrate.
Jan 09, 2010 • Cell Phones
How do you turn the ringer on the cd440 model?
The ringer on the Philips CD4402B/37 CAN be turned off by holding down the # key on the dial pad for about 3 seconds (see CD 440 Manual, page 8, Item "I"). And a little "canceled note" icon appears in the screen. To turn the ringer ON when it is off, do the same!
2answers
The phone does not ring - ringer is off.
firstly read the operations manual for that phone look on how to adjust the settings of your phone it probably sure was indicated there, because the way i see from what you posted it has no internal circuitry prob. it just needed an adjustment.. hope this advice helps... ;-)
3helpful
Panasonic KX-TG2343 cordless phone
I'm not sure about changing the amount of rings, but you can turn down the ringer.
1. Press the "menu" key, just below the "off" key.
2. Press the down arrow until you reach "Ringer setting," and then select this by pressing the key just below the screen on the right side (directly above "off" key) .
3. "Ringer volume" appears on the screen - select this the same way as you selected "Ringer setting."
4. Use the arrow keys to change the volume, and then press "Save" by pressing the same key you used to select.
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
