SOURCE: DIR-615 D-Link Router Problems...!
Try to reset the router first by pressing the reset button at the back of the router for 20 seconds then power cycle it by unplugging the power for 30 seconds then plug it back in. Here's how to set it up
1. You don't need to use the setup CD that came with it.
2. Make sure you have the proper physical connection
3. From your modem, connect the ethernet to the Internet/WAN port of the Dlink, then your computer to port # 1.
4. Do a power cycle. Unplug power to router and modem. Wait for 30 seconds. Power on the modem first, wait for all the lights to steady then power on the router. You should be all set
SOURCE: D-Link DIR-615 router
default username and password on the router should be
username: admin
password: *left blank*
SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
SOURCE: Problem for D-Link DIR-615 Wireless Router, Orange Power Light
I have had multiple problems with these routers. They tend to drop signals or have other issues that are hard to explain in a few short sentences.
After you rebooted did you open your browser and type in the IP address to connect to the router software?
can you be more specific?
Testimonial: "There was a problem with router itself, after replacement everything works fine. Thank you for an advice"
