. Ilve built in 900mm oven. Door does not seem to stay properly closed now, letting heat out. Seems like hinged door is loose and only stays tightly closed if I push on the door
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Most likely door hinges are weak. i have this video which might help you understand how door closes - springs on the hinges.
Hi david23413, it's the ILVE
service team here. Please contact our Service Manager, Peter Dale, on 02 8569 4672 to discuss your issue further.
Where can I buy replacement springs/hinges for an old enamel Welbilt oven? All the websites I've checked don't have them. Thanks for your help.
Hi I have a La Gemania stove and oven model M9060. The previous owner bought it in 2001. When we moved into the new house, we noticed that the oven door wouldn't close properly. When baking, the heat would get out of the oven and the panel became really hot. What should I do in this case? Replacing hinge or other parts? It seems difficult to get any parts of this product in NZ.
