This dongle ahould auto detect and auto install. Shut down your PC, plug in the dongle and re-boot. If the dongle is ok, windows will detect it and install the drivers. If you have an early copy of XP, you may have to download and install USB drivers.
Try opening the CD/DVD in Computer and then double click on the setup icon, this bypasses the auto boot which can sometimes have problems starting. Right click on the DVD drive where the installed media is inserted and then click open, look for the setup application then double click on it and that should hopefully resolve the issue.
The LaCie hard drive should have come with a CD. If you pop that CD in, then their directions make more sense: 1: Put in the LaCie CD 2: Double-Click on "My Computer" to open windows explorer 3: right below the "Local Disk (C:)" you should have a LaCie icon for your CD-rom -- double-click this icon for their setup assistant.
If you don't have a CD-ROM, you can still use the drive but it's more involved.
1: right-click on "My Computer" and select the option "Manage" 2: On the left panel of Computer Management, you should have an option "Disk Management" under the heading "Storage" - click on Disk Management note: The Disk Manager shows your current disks in the top right panel, and ALL disks in the bottom right panel. You might need to resize the window to see them all. 3: In the bottom right panel, find the grey-ed out box that corresponds to your new disk, and right-click on it. One of the options will be to format it. 4: After formatting, if it doesn't automatically come up with a drive letter, you can once again right-click on it in the bottom right panel of the Disk Manager and assign it a drive letter.
Once it has a drive letter, Windows should see the drive and you should be good to go!
Enter the "My Computer" icon on your desktop. From there you should find an icon named sims 2 or an abbreviation of that. Then right click on that and click autorun, if nothing happens right click then click open. Then look for a file named SETUP or a file with setup in it.
my computer
Sims2
right click on autorun or open and find the setup file
I just spoke to WD support...here is how to solve your problem:( I had the same problem and it works great now) 1. Connect your WD ext. drive. 2. Click open Computer. 3. Double click open the WD blue icon. 4. Double click open WD_Windows Tools. 5. Double click open WD drive manager. 6. Double click open the Setup icon for Vista 64 (the other icon is for x86 windows) run the setup and it will take care of your problem. enjoy!
Solution:- Step one: - Restart the computer Click Start and click Shut Down. Click Restart or select Restart from the menu. Click OK. After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved. If the issue continues, proceed to the next step. Step two: - Check the product cable Disconnect the USB cable from the product and from the computer. Wait 5 to 6 seconds. Reconnect the USB cable to the product and computer. After the product is connected to the computer, the product should start printing the jobs in the print queue. If the issue continues, proceed to the next step. Step three: - Determine whether the product is paused or offline Click Start and click Printers and Faxes. The Printers and Faxes window appears. In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens. On the menu bar, click Printer. Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it. If the menu includes Use Printer Online , click that option. If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes. If the issue continues, proceed to the next step. Step four: - Stop the print queue Double-click Macintosh HD. Double-click the Application/Utilities folder. Open the Print Setup Utility folder. Double-click the appropriate product in the product list to open the print queue. Click Start Jobs. Step five: - Delete the print jobs Double-click Macintosh HD. Double-click the Application/Utilities folder. Open the Print Setup Utility folder. Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue. Click Start Jobs. Double-click the appropriate product in the product list to open the print queue. When the print queue is empty, click Start Jobs. Try the print job again. If the issue continues, proceed to the next step. Step six: - Remove and re-add the product to the printer list Double-click Macintosh HD. Double-click the Application/Utilities folder. Open the Print Setup Utility folder. Select the appropriate product. Click the red X to delete the product from the computer. Disconnect the USB or Ethernet cable from the product. Close all open windows and restart the computer. After the computer is restarted, double-click Macintosh HD . Double-click the Application/Utilities folder. Open the Print Setup Utility folder. Reconnect the USB or Ethernet cable to the product. If the product is not automatically added, click Add. Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Open windows explorer.(START-PROGRAMS-ACCESSORIES-WINDOWS EXPLORER)
click the +, by my computer, click once on the cd rom, find the setup or autorun file in the right hand pane and double click it and the cd should start.
