Question about D-Link DIR-625 (790069292637) Wireless Router
I have a dlink dir625 router. I have windows xp on my desktop and cannot access the internet. I can access the internet on my laptop. When I am on my desktop and am trying to get on the intenet I am getting a warning int eh address bar that says internet explorer has modified page to help prevent cross site scripting. Then a bar pops up saying Access control and the address bar on the top of page shows http://dir625.bsecure.com/new device.aspx? then the computer sits and does nothing but flash access control on a bar part way down the screen. Hope you can help.
  • Pablo Gonzalez May 11, 2010
    reboot your modem and your router and try again. Don't know if you are hard wired to your desktop or if you are using wireless for it?
  • Al Kinsman Oct 21, 2014
    Thanks for helping ...got it figured out...cheers
    Scholar:
  • 98 Answers
Check parental controls for internet explorer. Open ie
click tools at the top, then internet options then content.
Under the content advisor option make sure parental controls are disabled
Posted on Apr 15, 2010
6ya staff
SOURCE:
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
Where can i find the set up wizard of my router
Just enter the default IP in a web browser. It should be 192.168.0.1
User: Admin Password: [none / blank] Unless it has been configured. To clear setting, just hold the reset in the back till it cycles.
This is demo: A non-functioning emulator to see the routers interface. Check it out.
http://support.dlink.com/emulators/dir625/109/login.html
Oct 16, 2012 | D-Link Dlink Xtreme N Gigabit Router...
I have configured my d link router and able to connect it with my win xp laptop and after i connect internet cable to the wireless router i am unable to access the internet through my win xp and win 7...
If initially the Win XP laptop was connected to internet at the cable/dsl modem, its MAC address would have been registered on service setup. If the router is now in place between the Win XP laptop and the cable/dsl modem, you would need to go on the Win XP laptop and log into the router as admin to clone the Win XP laptop's MAC address to the dlink router's WAN interface (internet facing side) so that the cable/dsl modem will see the previously registered MAC address and will enable the internet access.
Mar 23, 2011 | IBM Computers & Internet
DIR-625 (790069292637) Wireless Router: my router DIR625 is working for my desktop but not...
your router must be configured by your ISP so that it will be personalized and let them configure the laptop for wireless connection
May 17, 2010 | D-Link DIR-625 (790069292637) Wireless...
Is there any advantage using my DLink DIR625 with my Verizon 9100EM modem/router set up using WPA2? I have one ethernet tethered desktop and one laptop, plus using an wireless Skype Ipevo phone on the...
I can see no problem with that. But the WPA2 could be the issue. Some wireless device doesn't support WPA2 level. You can give it a try. For sure the laptop will connect. Not sure with the printer and the skype device. If they can't connect, use WPA only.
Jun 27, 2009 | Computers & Internet
Disable nat in dir625
I don't think you can with that model.
Mar 30, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Connecting with internet
Yes, that is possible since you have a wireless router. Router can share internet connection. Go to this link this will help you setup the wireless connection (secure it if you want)
http://www.portforward.com/english/routers/wireless/Dlink/DI-524/wireless.htm then on the very bottom there is an option how to Configure Windows XP to connect to your wireless network.
I suggest this because it would be better if there is encryption on the network so people wont be able to access your internet for free (unless you give them the security key)
Sep 15, 2008 | D-Link AirPlus DI-524 Wireless Router
D-link dir625
What kind of problems are you having? Once the router is connected to your modem and the router is configured and working properly you should be able to connect it to your PS3.
Mar 15, 2008 | Computers & Internet
D-link dir625
When your laptop is working, check the ip address.
Open your DOS PROMPT, type iconfig then click enter. If your ip address on the laptop is 192.168.x.x, that means that you are getting your internet from the router. If your ip address is (just an example:68.x.x.x, that means that the router is not functioning properly.
If the laptop ip is 68.x.x.x(just an example), make sure that your comcast modem is connected to the INTERNET PORT of your router.
You just bought your router so the best way to deal with this problem is call Dlink tech support so they can walk you thru the router configuration.
Good Day
Mar 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
D-Link DIR-625 (790069292637) Wireless Router Logo
448 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
