Whirlpool LER5636P Electric Dryer Logo
Posted on Apr 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just moved and outlet for dryer is different.
When i went to the hardware store and where you'd attach the cord there are four rings on the new cord but the dryer only has three wires not four.
Anonymous
Level 3:
President:
  • Master 1,554 Answers
  • Posted on Apr 12, 2010
Anonymous
Master
Level 3:
President:
Answers
1554
Questions
0
Helped
612175
Points
4917
Connect the red, black, and white wires of the new cord to where the red, black, and white wires of the original dryer wires are connected to but disconnect the ground wire (green/yellow wire attached to the cabinet) from where the white wire is connected to and connect it instead to the fourth green/yellow wire of the new cord.
My Gibson dryer has a three prong plug on it.I
The National Electrical Code began requiring 4-prong receptacles for 220-volt residential circuits in 2000, but it doesn't prohibit you from using your older dryer with a 3-prong cord. Instead, it allows you to change the cord so that the dryer can be plugged into a modern receptacle, and the procedure isn't very complicated. Four-prong dryer cords, or pigtails, are available at hardware and electrical supply stores, and usually cost less than $20. To make the switch, you'll need a green ground screw to attach to the dryer body so the machine can be grounded by the ground wire.
1 Unplug the dryer and move it to an accessible spot. Unscrew the plate on the back that covers the electrical terminal with a screwdriver. You'll find the cover on the back of the dryer near the bottom of the machine at the point where the cord exits.
2 Loosen the three terminal screws holding the cord. Before you remove them and take off the cord, note the colors of the screws and the wires attached to them. The screws holding the black and red wires are brass and the one holding the white wire is silver.
3 Remove the ground strap from the silver terminal. It may be a small metal plate or a length of wire connecting the terminal to the body of the dryer. You may be able to pull it out with pliers, or you may have to loosen a screw to remove it. Its function was to ground the dryer, and that function will now be served by the ground wire on the new pigtail.
4 Insert the brass terminal screws into the ring lugs attached to the red and black wires on a replacement pigtail and the silver screw into the ring lug on the white wire. Drive the screws into the same slots from which you removed them and tighten them securely with a screwdriver.
5 Drill a 1/4-inch hole in the body of the dryer within reach of the fourth wire in the pigtail, which is green. Insert a green ground screw through the ring lug on the end of that wire, drive the screw into the hole and tighten it securely.
6 Feed the cord through the notch on the terminal cover plate and screw the cover plate to the back of the dryer.
Things You Will Need
  • Screwdriver
  • Pliers
  • Drill
  • 1/4-inch drill bit
  • Ground screw
  • 4-prong pigtail
Tip
  • There usually isn't room behind the cover plate to install the ground screw. If not, it's acceptable to attach the screw to the back of the dryer outside the plate.
  • Check the grounding with a multimeter before you plug in the dryer. Set the meter to ohms, touch one lead to the dryer body and touch the other lead to the ground prong on the plug. The meter should show less than 10 ohms of resistance.
References
Sep 12, 2014 • Dryers
2answers
We just moved into an older home, the 220 dryer outlet is set up for prongs. I went to a hardware store and bought a Magnum 4-wire cord that matches the outlet. My dryer has a 3 wire cord. I removed the...
The red and black are the "hot" wires... white is the neutral and the green gets hooked to the frame of the dryer...
Here is a tip that gives more detail...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
My four prong plug Kenmore dryer is different than my four prong wall outlet. How should I correct this
What you will have to do is buy th correct cord for you outlet. Most homeimprovement stores stock the or appliance store. Get the correct cord for your outlet and replace it on the dryer and it should plugg-in. These are pretty simple to replace with an sdjustable wrench and a screwdriver.
Jan 28, 2010 • Dryers
2helpful
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Jul 23, 2009 • Dryers
Hi, I hooked up my LG DLE5955W dryer and it powers up fine but I have no heat. The outlet I had for my old dryer was different than the one required for the LG. I went to home depot and got the correc
The following link explains how to properly wire a three or four prong 220VAC appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link provided, and make sure you have the power cord wired correctly at the terminal block in the back of the dryer. NOTE: If this is a new installation, you are required to be using a four-prong outlet with 4-prong power cord. If you have any questions, please let me know. I hope this helps solve your problem.
1helpful
What type of electrical cord do I need for a Maytag dryer m# mde2500ayw
It depends on whether you are using a three wire outlet or a four wire outlet. Eithe of these cords are standard and can be obtained at your local Home Depot, Lowe's or hardware store. It is a 30 amp dryer cord.
Apr 08, 2009 • Dryers
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
I have a dryer with a 240v 30amp plug i just moved to a house that has a 250v 30 amp outlet what can i do this seems to be the new standard
go to a good hardware or home center store and look at the dryer plugs if they are the same as the one you have good if it differs buy new cord replace it wire for wire at terminal block in rear of dryer
Jan 26, 2009 • Dryers
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
