The keyboard on my Acer Aspire One netbook is driving me crazy! Some of the keys won't work such as the o and left shift key. Then some of the keys give alternate characters such as ( > )instead of ( . ) Also, when I try to highlight a word the whole sentence gets highlighted. Any thoughts on this?
If you have a way to visit the Acer Support Team website
https://www.acer.com/ac/en/US/content/support
They would provide assistance on how to resolved your keyboard problem
Note: They would verify the warranty of your laptop
If the warranty is expired they will give you options on how can they provide support.
SOURCE: keyboard problem
Information about computer keyboards
Now with new technology, stuck keys are no longer an issue; ... Given all the above problems
Information about the AT and PS/2 port
1, Keyboard Clock. 2, Keyboard Data. 3, Not Connected or Keyboard Reset
Device Manager information and help
Users who have a keyboard with a windows key may also quickly get to the system .... CODE 2 (Second Error)
This should get ya back in to typing again/Good Luck.. Please dont for get to Vote, Thank You.
SOURCE: Acer Aspire Netbook..Can't use keys or right/left click.
go to control panel then mouse properties you will see the buttons the left & right then click the task that you want to do.
SOURCE: how do I remove the keyboard on acer aspire netbook
Hello
I found this Video where you get exact instructions on how to remove the keyboard. Just click on the link and you will be directed to the video link. Hope this can help you.
http://www.youtube.com/watch?v=FoTwln2SyQ4
Kind regards
Andrea
Testimonial: "Thanks! That is exactly what I needed !"
SOURCE: how do I pop a key back on my keyboard acer aspire
There's a small plastic spring type clip that fits under the key. It has little nubs that stick out the side and fit into slots on the keypad base. The nubs break and your lucky if you find a replacement that stays in place long. You can get a new keypad for about 40 bucks on ebay and replace it in about 10 minutes.
There's a plastic trim strip across the top. pop one side with a small flat screw driver, remove, 2 screws at the top of the keypad and a ribbon cable to the motherboard. When removing the ribbon cable there's a small lip at the top of the connector, carefully lift that lip and the ribbon will pop out. Have fun
SOURCE: cant get rid of bilingual characters on acer aspireone netbook
Check your regional settings in the controll pannel. Your keyboard is probably set for "Canadian French"
By default it should just be set to US.
