I have had a Mitsubishi DLP 52525 for 2+ years now and recently the green timer light started to rapidly blink when the unit was turned on and it continued to blink without the picture coming on. After discconnecting the power and then using the system reset button, the problem remained. I swapped out the lamp and the tv worked for about a day and now the same problem is occurring. I have hit the system reset button but to no avail. There is nothing in the manual that deals with what is indicated by a constant blinking green timer led. Looking for suggestions. Just did the repair that Chris mentioned by changing out the 4 caps and no change. Plugged the set in and the green light on the front continues to blink. Hit the reset button and no change. Suggestions? Ideas ? This is on a 2004 WS-48513 Mitsubishi.
Check the pico fuses on the reverse side of the DM , Just check them in circuit for continuity. let me know how you make out, and if you need any more advice lert me know
Can you help me identify the Pico fuses?
Once I find them just use a VOM to do a continuity test on them?
Thx,
Joe
Can you pls give me some idea where the fuses are? What they look like?
Thx,
Joe
