UE stands for Unbalance Error. If the washer has tried to spin numerous times, tried to redistribute the load itself between each attempt, and still not been able to get the load up to full speed without experiencing an off balance condition, it will finally stop and display the UE code. This is most often the case when a heavy / bulky item(s) are being washed and the spin speed is set very high. When washing these items, set the spin speed to low. The machine will most likely be able to handle that. If you want them spun out faster, then AFTER the washer has made it through the cycle on low speed spin do this: Turn the power back on. Without selecting any cycle, just press the spin speed button, selecting the next higher spin speed. Now press start, and your washer will just do a 14 minute or so pump and spin.
For super wet heavy loads, if you cannot even get the washer to go through a cycle on the lowest spin speed, you may have to wring a bunch of the water out of the clothes by hand before doing the 14 minute cycle thing.
