Kodak EasyShare SV811 (8858946) Digital Picture Frame Logo
Posted on Apr 11, 2010
I deleted all the pictures I had on my frame and now I can add any on it. I keep getting the message The item ?DSC03154.JPG? can?t be copied because there isn?t enough free space. everytime I try to put a picture on it. What is the problem?
Anonymous
Level 1:
  • Contributor 31 Answers
  • Posted on Apr 11, 2010
Anonymous
Contributor
Level 1:
Answers
31
Questions
0
Helped
9688
Points
61
Sounds like the memory installed in the frame is full. Try a different memory card or USB stick to see if the various ports are working. Be sure and try a full power off, batteries removed, reset. On the menu, is there a "format" function? if you reformat the memory, you will lose all of the pictures, make sure you have other copies, but that should return it to factory condition.
How to copy pictures in digital frame internal memory
http://www.digitaltips.org/imaging/digit... ...
The following items about digital frames are from the link above where you may find additional information.
Memory
Another important feature to consider is how many images you can store on the frame. Most have slots for loading pictures directly from a camera's memory card. Make sure it accepts the same type or types of cards that your camera(s) do, as this will make transferring images to the frame significantly simpler. Also, look for a frame with a large internal (built-in) memory if you plan on loading lots of images for slide shows, videos and so forth.
Connectivity
With all the attention your digital frame will get from friends, family and members of your own household, you'll want to keep it updated with your most recent photos. Having multiple connectivity options can make this task a lot simpler. Most frames can connect to your PC using a ubiquitous USB cable, while Blue tooth and WiFi-enabled frames let you sync wirelessly from laptops, camera phones and cameras that are WiFi enabled. Many WiFi-enabled frames can automatically sync images from PCs on your home network or from photo sharing sites on the Internet, making it simple to keep updated.
If your computer has memory card slots, you can copy from the computer to a memory card.
If there are no memory card slots on your computer, purchase a Targus card reader at Walmart for $8.88 or another brand for less at Ritz/Wolf/Kit camera. Also, they do 3½ x 5" digital prints for 6¢ each on Tuesday and Wednesday.
CAUTION To prevent memory card corruption, keep batteries charged and don't delete. Wait for lights to stop flashing then turn camera off before removing memory. For card readers, double click Safely Remove Hardware. Select then click Stop and OK.
Have just been playing with this and found that it works really well, but you should first format the memory card in the camera because it adds files to the card you will need.
Next, take a picture of something with the camera.
Place the memory card in the card reader and go to My Computer.
Open the memory card and you should see a folder on the left (DCIM) that has your picture. Do not open the MISC folder on the right.
Double Click on the DCIM folder and you should see another folder (e.g.,100HPM417) which includes the name of your camera. Double Click on that folder and you should see the picture you just took.
When you copy from the computer to a memory card, that is the folder where your computer pictures must be copied. You may only be able to copy one picture at a time from My Computer.
One last thing, the file names of your pictures must not have any additional letters or those pictures will not be seen by the camera. Also, the file name format must match the file name of the picture you took e.g., HPIM1903. Rename files to the format of your camera photos.
If you have trouble with this, it may be easier to right click on Start and then left click Explore. Find and select the pictures you want to copy and then near the top left, click the X next to Folders to see a place to select Copy files. You can then select the memory card folder e.g.,100HPM417, that you clicked to see the picture you took and click Copy. You can copy pictures easier with this method.
Click this link for other camera tips and complete instructions on cleaning camera and battery electrical contacts. ...
http://www.google.com/base/a/4210404/D13...
Thanks.
Mar 11, 2011 • Cameras
3helpful
I cant save my messages to my memory card
In nokia 3230 you cannot save the messages to memory card.You dont have option in this mobile itself.
Dont worry, please download MSV driveE software in your mobile phone so that messages can been directly saved in MMC.
Download the MSV software from below website
http://www.ziddu.com/download/8277766/MsvDriveE.jpg.html
After you downloaded it, you’ll find that you save file named MsvDriveE.jpg. Don’t worry! You just downloaded the right file. Rename the extention *.jpg, and change it to *.sis. Then you’ll get MsvDriveE.sis then install it to your phones.
But in this feature it just saves the incoming messages to the memory card instead of saving it to phone memory to keep the phone memory unused.But you cannot read your messages.
To read your saved messages in PC please install a software called as FE explorer.
You can download FE explorer from below website
http://gallery.mobile9.com/f/1210278/
Using this FE explorer you can copy the messages in your inbox and you can paste in any of the folder in memory card.Then you can open the messages in your computer using Note Pad and read the messages.
To copy please follow the below steps,
1.Select inbox from the main page in FE explorer.
It shows the messages in Your inbox,sent item,saved messages also.
2.Copy it and Paste where ever you want to copy in E:/ drive(Memory card)
3.Then you can put your memory card in your PC and can open up the messages in Note Padfd6f18b.jpg Thank you
3helpful
2answers
How to play PPT on Pandigital Electronic frame?
You cannot play a PowerPoint presentation files on the frame. However, if you add still images (JPG) and music (MP3). The frame can play it's own slideshow.
1helpful
Built in memory full...?
I have new camera ,After shooting 12 photos it's show Built in memoru full and cannot shoot anymore
Transfering photos from my laptop to the frame.
If you can see the photo frame connection in your pc, you should be able to copy the pictures and paste them in the photo frame's folder.
If you already have some photos in the photo frame, look for the containing folder in the photo frame's drive. Save the new pictures in the same folder.
Note: You should be aware that the pictures should be in jpg format. Some photo frames do not accept png and gif formats.
If thats the case, go to "Paint" program in your notebook.
Open the file then save it again using "Save As" to "jpg" format.
Recopy the pictures and paste them in the photo frames folder.
Please rate this solution.
Jan 16, 2009 • Cameras
Bad jpg message
It can be a variety of problems, unfortunately. The images may just be truncated from the get go. Make sure all the extensions are lowercase .jpg. If they are not, OPEN them in a program, save as .jpg, close and reload them.
Do not try to just change the extension, this corrupts the image.
Also, check the size and make sure they are not too large.
For the digital picture frames, a 5x7 at 72 dpi is plenty big. Just make sure not to override the originals with the compressed images.
Then, check the name of the pictures. Remove any spaces, dashes or any other symbols. Strictly use letters.
When all else fails, delete all the images from the frame and reload them again.
How are you loading the images on the frame?
From a card, or directly from the computer?
If from a card, make sure to eject it from the computer first, don't just pull it from the reader. This can really messes it up and the images. Same goes with the frame itself.
Hope this helped.
I'm trying to transfer pictures from my computer to the picture f
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
2helpful
2answers
SmartParts Frame SPX7E only allows me to load 165 photos
2 answers...
To remove a picture, connect the frame to your PC via USB. you should see the frame appear as a drive, in my case,
36972 (E:)
open the drive as Explore, you can now see the pictures, and delete what you no longer want.
you can download the software from
http://www.smartpartsproducts.com/content/support/optipix/index.php
I can't figure out how to delete individual pictures from display
The photo frame's interface doesn't provide any file management, so you can't delete, copy, move, or rename files on the display itself. Why can't you delete files on the card using your computer?
As for the problem with cutoff heads, etc.. Spend some time on your computer to make all your images in 640 x 480 pixels in size and save them all in .jpg format. This should solve your problem and makes the display work quickly.
5helpful
Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
Dec 11, 2007 • Cameras
Top Kodak Photography Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Kodak Photography Expert? Answer questions, earn points and help others
