I have a canon powershot s3 is camera, and when turning it on the lcd screen stays black. The other features seem to be working fine.
SOURCE: Canon S3 no display on LCD screen
try removing small buton battrey under cover "CR1220"
in battery compartment
to reset camera
replace
then reset time
that fixed mine
SOURCE: Canon Powershot has black LCD screen
Best Solution worked for me?!?!?. Not sure if following the instructions got the screen to come back, but it did come back. I just flipped it over to movie messed with the settings and then open up the battery door which turned off the camera. Closed the door, Flipped to photo and turned it back on and it workd. This is the second PowerShot that I have had, current SD750 and an old S230, to do this.
SOURCE: my lcd screen is blank but the camera acts like it
Had the same problem with my S3 is and couldnt find any help other than to junk it and buy another camera. WAY too expensive to repair (out of warranty)
I found a post and this worked for me...just fixed it about an hour ago. Mine would show a blank screen on the LCD nothing thru the view finder other than the menu screen. Found out the shutter was stuck and that seems to be a common issue with these cameras. This is how I fixed mine.
1. set the shutter speed to the longest setting you can. I put mine on the TV setting.
2. close the flash and set turn off all of the functions you can to conserve the batteries.
3. take a picture and within 5 seconds open the battery door. Then close it back and repeat. Your trying to interrupt the shutter reset process thereby "unsticking" the stuck shutter.
4. If this fails then try LIGHTLY tapping the camera against a piece of wood, again to unstick the shutter.
Sounds like a bad idea but considering I had tossed my camera in a drawer and already replaced it, I didnt really have much to lose. I was pleasantly suprised to see that after about 15 resets (steps 1-3) and a couple of light taps, the camera is working good as new again.
Good luck, hope it works out for you!
SOURCE: I can see the menu and icons on the LCD screen,
It is known problem of ccd imager failure in S3IS Canon camera and ccd imager chip will be replaced to get live view to take fresh picture.
Local camera repair shop will repair camera by replacing ccd imager chip because camera will take apart and soldering work is also involve so its not likely novice fix.
Thanks.
SOURCE: Blank screen on Canon Powershot S2is camera
hi.if you are telling both viewfinder and lcd are blank or black the problem is in the shutter that you found inside of the lens are not open.sometimes the cuase of the is humidity or moist goin inside of the shutter thats why it will not work properly or stuck up.if you can open your camera and adjust the shuuter from lens unit its better .but if not its better you bring to service center and request for adjustment.
by the way try also to reset your camera to default setting maybe it will help you.
thank you
Testimonial: "Thank you so much for taking the time to help me, i will try your suggestions tonight, really appreciate your help, thanks again"
