This may be because your paper had lost its temperature. Papers should have a minimum temperature to be accepted by the printer. papers exposed to atmosphere for a long time may not have this required temperature. You should try to keep paper inside some drawers or something and take out papers only when it's actually needed.
i lost my cd of Hp Deskjet F380 and i want to install now to my cp, secondly it use to show me red light blinking saying paper jam while there is no paper jam inside the printer for now she is not working
check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
hi, HP Officejet 5610 All-In-One InkJet Printerhas few common problems. Such asDriver CD lost,Scanner does not work,Connection problemetc. For find all these software solution just clickhere....
E and number 2 just says to reload paper and try again. Look inside for any paper scraps or things that don't belong..I usually find paper clips, gum wrappers, gummy bears. Around the area where the paper should feed in.
if printer not show any error message (and in ready mode) then place a art sheet in tray and print a page attend paper forcefully by hand to remove lost paper with this art sheet
if printer show any error message like paper jam try to remove with open the front door
The button above the ! is paper jam indicator. Does the light appear immediately after powering on the printer. If yes check paper sensors. If it only comes on after trying to print, it could be a paper misfeed.. Check the feed rollers.. you can turn them inside out for better grip on the paper as a diagnostic method.
Sorry for late answer. First reset your printer by unplugging the power cable for a couple of minutes. Open the printer and check for paper stuck inside, check also for lost foreign objects inside the printer (eg small screw) by turning it upside down. Try also moving gently the printer head (cartridge slot) on the rail.
If after this you still get the error message then you probably damaged some mechanics inside the printer, in this case you will need to have printer serviced.
