Could be start winding or capacitor yes it can be rebuilt. You save about 100.00.Just had mine re done. hand wound winding new bearings new seal new capacitor.184.10. bearings better than original rubber sealed,. winding ealeded and baked . better than oem. find ac electric motor shop in ur area chancecs are they doo pool pump motors.
No...write down all the numbers on the ID plateand go get a new one...the numbers will make sure you get the exact motor you need...electric motors are general, based on the numbers...
Thank you for posting your question here on Fixya.com.
Your motor bearings are failing. It is most often caused by a leaking pump seal. It is a relatively inexpensive repair if it is caught early enough; before the shaft is damaged from the corrosive water eating into the steel. Take it to a local electric motor repair shop for inspection. It will likely need a set of 203 bearings for the motor and a mechanical seal for the pump. All told, depending on the labor rates, it should be less than $75. You could try to repair this yourself however if you are not familiar with the process it is money well spent having someone who is do the repair for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
