Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
Posted on Apr 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Primer bulb-carb routing
I have a Poulan Model 2075 chainsaw. The primer bulb cracked. I replaced it and installed a Walbro D10-WAT carb gasket kit. In the process, I forgot the proper routing of the fuel lines from the fuel tank to the carb and primer bulb. Can you help me?
  • Anonymous Mar 19, 2014
    primer bulbe has no fuel
Anonymous
Level 3:
President:
  • Master 2,220 Answers
  • Posted on Apr 10, 2010
Anonymous
Master
Level 3:
President:
Answers
2220
Questions
Helped
1383460
Points
7625
It should be like this.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
How to rout fuel lines to primer bulb on poulan 14" chainsaw
Short line on primer bulb goes to the left side of the carb. The long side on the primer bulb goes to in the fuel tank as the return line.
5helpful
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
7helpful
Walbro WT891 carb on a Craftsman chainsaw. Carb is brand new, all fuel lines and fule filter replaced. I prime the carb with the little plunger, chainsaw starts up and runs out of fuel within 30 seconds....
Who connected these hoses? the normal routing for a machine with a primer is like this, the fuel hose from the tank with the filter on the end goes to the carb fuel inlet nozzel ( not to the primer ) nearest to the pump cover ( cover on carb held with one screw ) the pipe from the metering side of the carb connects to the shorter nozzel on the primer bulb ( suction side ), the longer nozzel on the primer ( pressure side ) connects to the pipe going back to the tank, just remember the primer pulls fuel from the carb,into the bulb, and pushes it back into the tank, it is not actually a primer it is a purge. because it is connected this way it is impossible to flood the engine no matter how many times the bulb is pressed.
Let me know if it starts and runs.
4helpful
2answers
Need to know how to connect the gas lines from the primer bulb to the carburetor on a poulan woodshark model 1950 chainsaw
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
No gas to carb
There should not be a vent hose--it probably goes to a port on the primer bulb. Check the fuel filter for plugging and the condition of all fuel lines (they should be original rubber, not plastic replacements). Try priming the carburetor with the bulb pump--it should pull fuel into the bulb after several pushes. If nothing, check the condition of the primer bulb--it should be soft without cracks or holes.The primer is supposed to pull fuel from the tank's fuel filter, into the carburetor top section, pass into the lower section through the metering valve which is controlled by the diaphragm, then out to the input port of the primer and out the other primer port to return fuel to the tank. Go to: http://www.drystacked.com for an excellent 12 page article on theory and troubleshooting of Walbro carburetors. Hope this helps!
5helpful
2answers
Model 2175 poulan - pump up primer bulb and it colapses. When i put fuel in head it runs till gone..
Change out the primer bulb and the small gas lines going to carb and primer. One of these has a small crack to let air get by and this is how you get a flat primer bulb. Pick the kit up at lowes for $6-8.
2helpful
Trying to put new fuel lines in all around... bulb has two connections, tank and carb. carb has two connections, I imagine that the tank/filter line goes into the carb, carb then goes out to bulb, bulb...
Fuel routing:
Tank to carb (filter on free end in tank, replace annually)
Carb to primer (primer sucks fuel through carb)
Primer to tank (primer returns excess fuel to tank) HTH
Lou
3helpful
Poulan 2150 type3 / a show me diagran of fuel line hook up from primer bulb to carburator
I have a McCulloch 3200 chainsaw with a cracked primer bulb and all the fuel lines were gone. I cannot locate any information on routing these lines to the carb. I have a new primer bulb and 3/32x3/16" fuel line. Please help me solve this problem.
3helpful
Poulan 2150 fuel line routing wt324 carb
the large hose from the tank goes to the suction side of the primer bulb. The large line from the out put side of the bulb goes to the bottom inlet of the carb.
the small line goes from the top outlet tube on the carb back into the tank near the primer bulb.
11helpful
2answers
Walbro wt hose routing on poulan saw
Carb has 2 nipples. top nipple gets line with filter on it from tank, bottom nipple receives line from bulb other side of bulb returns to tank
Top Poulan Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Poulan Garden Expert? Answer questions, earn points and help others
