How do I reset my 920 ink cartriges on my hp 6500 printer
Hi Rjwb,
Download the manual for HP 6500,
HP OfficeJet 6500 Wireless Manual.
It is clearly mentioned in it.
-Rate if it helped you.
Hello, please go through the below mention HP website it will help you replace the Cartridge.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01638333&lc=en&dlc=en&cc=us&product=3795406
SOURCE: RESETING INK LEVELS???
We recently purchased and installed an HP Compaq presario, and now we don't get the printing display in the lower right corner that would indicate the task in progress with page of page, number of pages and...ink levels. Also we can't cancel a project in 'mid-print' without turning the printer off and on again/
SOURCE: the ink system has failed
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: hp 920 xl ink cartridge filling instructions anyone have them
I used the drill method in the video. Took a while to get it printing again but so far, so good. THe low ink light went out so the pritner thinks the cartridge ink level went up as it did.
Will post again if it breaks.
Dr Bill
SOURCE: Keep getting display check and remove cartridges,I
Clean the golden contacts on the ink cartridge and in the cartridge cradle using a soft tissue.
SOURCE: HOW TO RESET 920 INK
FYI,
you cannot reset the ink it self.
If your using an HP refilled ink cartridge the warranty of your printer will be void.
you need to contact HP right away to purchase new ink cartridges.
If the cartridge has been refilled or remanufactured, 'Low on Ink' or 'Ink Alert' messages may be inaccurate or display incorrectly.
