Where did you find the replacement Price Pfister Marielle Kitchen Faucet Matching Spray Kit? (sprayer/hose) Is it all 1pc or can we buy just a new hose. Head seems attached as all 1pc so far?!?
Is the plate damaged? If so you should be able to get another at the hardware store. Will it slip over the sprayer? If not you will need to turn the water off at the cut off and unscrew the sprayer hose the pull hose through the sink hole and put the plate over the hole then the hose goes back through the hole and screw it back on under sink. It should be good to go.
Most new kitchen faucets feature single-handle control levers and washerless designs that rarely require maintenance. Additional features include brushed metallic finishes, detachable spray nozzles, or even push-button controls.Connect the faucet to hot and cold water lines with easy-to-install flexible supply tubes made-from vinyl or braided steel. If your faucet has a separate sprayer, install the sprayer first. Pull the sprayer hose through the sink opening and attach to the faucet body before installing the faucet.
Where local codes allow, use plastic tubes for drain hookups. A wide selection of extensions and angle fittings lets you easily plumb any sink configuration. Manufacturers offer kits that contain all the fittings needed for attaching a food disposer or dishwasher to the sink drain system.
The hose that goes to the Sprayer has to be disconnected under the sink at the main connection there, then it can be pulled up and out of the top of sink. the you can unscrew the nut under the sink on the flange and remove and replace.
with the water off remove the sprayer head, hold hose and slowly turn on the water and see if anything comes out, it may just be that the head is clogged up and needs to be cleaned or replaced.
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
