I have been attempting to use an external hard drive. When plugged in, I get a Windows Code 43 error. I have tried to update the driver and have also disabled and enabled the driver. It keeps on asking me to format but this can't be done because of the files that I require.The software for the drive does not install. I can't do a check disk for errors cos it can't be found by the OS. Point me in the direction of up Thank you Ian Cooper
Easy way to fix windows error code 43 in windows 10 online or call +1 (800) 848-5295for help
SOURCE: i cannot reformat my pc windows xp,there's an error
If you are getting an error during installation its not good :(
Its prob either yor ram or hard drive faulty. Download memtest and test ram 1st as thats the most likely cause. Check that optimised defaults are loaded in bios also.
SOURCE: XP upgrade to Vista install error code 0x800705AA
This error is something to do with the "Product Key" I think I have Googled this error and this is what shows up the most? I googled ... vista install error code 0x800705AA .... so perhaps ya can follow up in this vien... Good Luck
SOURCE: Cannot install Windows XP,Vista on Compaq Laptop(FreeDos) V3607TU.
Disable the SATA option under advance options in BIOS. That should work and it will also allow you to install/reinstall Win XP.
[email protected]
SOURCE: ACER 4720Z
It's very easy. You can switch SATA mode from AHCI to IDE (in Bios) and install XP, or leave AHCI mode, with 'nLite' integrate AHCI drivers into XP installatin files, burn and install... Drivers are not problem, just search in google, even ePower tools are working.
SOURCE: need a free sound driver for windows xp
http://www.station-drivers.com/page/realtek.htm
try this driver i think its realtek driver you download driver see it may work
