The shelf frame is cracked . It can be purchased if the part is still available from LG . I wouldn't hold out hope though because LG is notorious for discontinuing parts after 3 years. Find a parts supplier who has contact with LG parts to see if it's still available . I was able to order one for my customer back in the spring.
SOURCE: LG LRFD22850 Replacing support grid for bottom crispers in refrig. Need help.
It is a challenge to replace those grids. Instead of trying to fit the support grids into the frame, bend the frame slightly to fit the grids. You will need to remove the steel support from the frame before bending the frame. That is what I have been able to do when I have those problems.
SOURCE: Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
SOURCE: Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
SOURCE: Crisper drawer support has fallen out
The rod has to be inserted inside the front of the assembly. Take the assembly out, flip it over, and look for the small spaces on either side of the front of the assembly. Slide the rod in.
