The flame on my SAR134A/X frequently extinguishes during cooking or an individual gas ring fails after ignition with the ignition button is released.
This is an intermittent but annoying problemThe flame on my SAR134A/X frequently extinguishes during cooking or an individual gas ring fails after ignition with the ignition button is released.
You can't post conmments that contain an email address.
Give it a while for the switches to dry if it doesnt start working then reply to me most of the time they will start working also check to make sure the breaker didnt trip
Mine doing the same as well - 3 of the four lights automatically but the one must be lit manually ?Mine doing the same as well - 3 of the four lights automatically but the one must be lit manually ?
Brand new means you have a warranty, get the service agent to check.
I have found that you can easily place the wrong burner cap on the incorrect burner ring(the smaller burner caps).
Could also be dirt or water in burner ring or the burner jet(use needle to clear jet).
Are sparks coming from all ignitors? You might have damaged the spark plug.
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
We have an older Thermador Gas Cooktop type range. It was working fine until the cleaning crew came in, then all the burner igniters were clicking when turning on a single burner. I solved the problem by cleaning off the igniters. I first of course unplugged the power. Then I took a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. I then went ahead and scraped and brushed clean the mating surface where the spark travels. I then vacuumed up the mess. My burners all worked great after this. Hope this helps!
problem with hob is probably water ingress in area of ignition unit - will probably cure itself
oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
