RCA M4304  Digital Media Player Logo
Posted on Apr 09, 2010
Loading Trying to start the RCA player, and it keeps showing up as Profiling requires 20mb space, and then shuts down, it also isnt showing up on my computer at all
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
270
Points
I have the same problem and its ********
1helpful
My Thomson 6728 keeps showing ! Profiling requires 20MB free space Shutting Down
3helpful
Profiling requires 20mb free space. shutting down
Delete up to 20 MB of space on it and let it profile.
3helpful
I keep getting this error... "Profiling requires
Hi,You just need more space on your player. Just connect to your computer, back up files, then delete enough to leave 20mb. Hope this helps! Oh and for all the support for the M4304 visit this page:http://www.rcaaudiovideo.com/product.aspx?product=420
1helpful
The mp3 won't stay on, it'll turn on and say "profiling requires 20mb free space shutting down!" what do i do?
the data may contain virus. backup the data and format the memory and restore the data.
3helpful
2answers
My rca m4304-A mp3 player says profiling requires 20mb free space shutting down and then when i try to hook it up to the computer it will not show that it is hooked to the computer and goes off
Restoring RCA M4304A Recorder Firmware
Symtom: recorder shows OPAL splash screen, then shows "profiling requires20mb of free space, shutting down" and then shuts down. Recorder cannot be accessed by windows or the RCA easyrip software.
Solution: Use the firmware update found here: http://www.voxxsupport.com/images/downloads/OPAL_066F_85A4_85A5_0_1140_SIG.EXE
This update needs to be ran on an xp computer running 32 bitOS. It was tested in a Win 7 64bitmachine and proven to not work.
Necessary steps taken to get the firmware to properlyrestore were as follows:
1. Hold in the power (menu) button for 10 seconds(the splash screen will show and it will give the error message, ignore it)
2. While still holding the power button, press theplay/pause button and hold down.
3. Release the power button while still holdingdown the play/pause button and wait 5 seconds.
4. While still holding the play/pause button plugin the usb cable to the recorder. Continue to hold the play/pause button foranother 5 seconds after plugging the cable in.
5. Release the play pause button then launch theEXE for the firmware update. Minimize the instruction screen so you can see thefull update screen.
6. Leave the format checkbox checked (check it ifit isn't checked) formatting is crucial to this working.
7. Once the status in the update window changesfrom initializing to ready click start to update the recorder. It will go through formatting, then updating.
8. Once the status shows complete disconnect therecorder and with any luck the recorder is usable again. The media files will obviously have to bereloaded, but the recording is functional at least.
How do you fix your mp3 player rca pearl when it says profiling requires 20mb free space
Make sure you have 20MB of free space available on your device. You can do this by opening "My Computer" and right-clicking on the drive letter associated with your mp3 player and select properties. Remove media until you have at least 20MB of free space available.
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
