The shutter inside lens doesn't work, it could be a broken shutter cable which happens to break on this model (also V803). It is a well known problem and the only solution is to replace the shutter unit or whole lens unit. You will have to contact Kodak. It might be cheaper to buy a new one (at least in the USA).
Make sure that you are installing a fresh/ full charge battery
Remove the battery Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt. If you do not have access to a dif. battery. Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
A new screen is availably from virtualvillage dot com for about $45. I replaced one last week. It only takes 20 minutes and a small screwdriver. The ribbon cable is held in by a flip up lock at the main board.
The screen must be replaced. To do it yourself, the screen will cost around $40 from virtualvillage dot com. I just did one. It took about 15 minutes. The ribbon cable is held in by a flip up lock on the main board. Otherwise, it's just remove the screws around the case and pull the bottom edges outward first.
virtualvillage uses Pay Pal only.
Hello. We konw someone sell Kodak V803/V1003 LCD on ebay. Please visit the following link or search item number 320277003613 on ebay. Thank you http://cgi.ebay.com/KODAK-V803-V1003-REPLACEMENT-LCD-DISPLAY-REPAIR-PART_W0QQitemZ320277003613QQihZ011QQcategoryZ64352QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
unfortunately it would appear to be a CCD or main board failure.
If the camera is out of warranty (as this should be covered) my best suggestion is to pick up one off ebay with a broken screen and put your screen in it, broken screens are common on these cameras so they go quite cheaply, far cheaper than kodak would charge for repair and the swap is easy.
There are several searchs to try "parts v1003" "spares v1003" "Faulty v1003" "repair v1003"
The following procedure works on the V1003. It uses the same LCD screen as the V803.
It would appear you have a damaged LCD screen. The same problem happened to my daughter's V803. The camera will take pictures fine but you will only be able to see them if you download them onto a PC. A replacement screen can be easily ordered and replaced. Call Eastman Kodak. Their parts department can be reached at (800) 431-7278 ext 3. Tell them the model number of your camera and tell them you want to order a LCD screen for it. The cost of the new screen is $31.00 + $15.00 shipping. Don't let them talk you into sending it back for repair. You are looking at a repair bill over $80.00. To replace the screen, remove all of the small philips head screws that are in the chrome band that runs around the center ridge of the camera. After removing the screws, you will be able to separate the rear half of the camera from the front half. The LCD screen is pressed into a rubber gasket in the rear half of the camera. You will see that there is a small, flat orange ribbon cable that connects the old LCD screen to a black connector on the camera's motherboard. Using a VERY small flat blade screw driver, pry up the top tab on black connector. This will unlock the connector and allow you to remove the flat ribbon cable from the black connector. Remember the orientation of the old screen and its cable as you will want to replaced the new screen and cable exactly the way the original was installed. Using the same small flat blade screw driver, pry out the old display. Install the new display into the rubber gasket into the back half of the camera. Insert the ribbon cable into the mother board's black connector and press down on the panel to lock the cable into place. Lay the rear half of the camera face down on the table (rear buttons facing down) and place the front half of the camera over top of the rear half. This will allow you to put the camera back together and help prevent the new LCD screen from falling back out. The LCD screen has pads attached to the surface behind it. When you reinstall the front half of the camera, those pads help hold the LCD screen in place with pressure from the motherboard. Replace all of the screws. If you did it correctly, the camera will operate like new. Last word of advice. Buy a padded hard shell case for this camera. These cameras are well known for LCD screen failures due to shocks and drops.
