SOLUTION 1)
Try this...Go to http://www.apacer.com/en/support/downloads/Repair_v2.9.1.1.zip
(the software is model/manufacturer independent.)
Be careful to have only the flash drive you need to repair connected to your computer, as the software has no controls, and doesn’t even allow you to choose which drive you want to format - seems like it assumes the first removable drive available is the one you want to format. If the format "fails" then quit the tool , then try format in Winxp.
SOLUTION 2)
Check out the registry under
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
The value 'WriteProtect' should be absent or set to '0'.
