My brother problem is troubleshooting and routine maintenance
clean unable 46
C D WORLD NAGPUR 09960014121
HI ALL HOW TO CLEAN DCP ERROR CODE 46
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1.
press buttons Set, Menu, Mono Start one by one, followed by up arrow
key four times. this should all be done as short a time as possible,
around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Brother 165 Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide". I went to user's guide and cleaned all the parts inside the printer. Still flashing message. How can i clear ????
The ink absorber box and the flushing case will need to be replaced. Then the purge counter and the flushing counter will need to be reset to 0.
the reason is doing lots of prints and/or copies.
The cost of parts and labor averages about $100.00.
if you were able to reset it without changing the pads you have a high-rick of getting ink leakage.
Thanks and please rate this support.
SOURCE: my brother printer DCP135C have
Try to reset DCP printers without numeric keypad.
Follow this:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
Don't forget to vote Thanks!!!
Testimonial: "fantastic answer, it is very very helpful to solve my printer problem. thank you very much"
SOURCE: clean unable 46 printer not working give only
follow the instruction on this site
http://pcmediks.blogspot.com/2010/09/how-to-reset-brother-dcp-195c-model.html
I do not understand the question????
