Electrolux Over-the-Range Microwave Logo
Posted on Apr 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave makes a loud hum and won't heat. What
Microwave makes a loud hum and won't heat. What might the cause be?
Anonymous
Level 3:
  • Electrolux Master 43,501 Answers
  • Posted on Sep 30, 2010
Anonymous
Electrolux Master
Level 3:
Answers
43501
Questions
0
Helped
10844015
Points
101584
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgf
2 Related Answers
Anonymous
  • 70 Answers
  • Posted on Aug 18, 2009
SOURCE: Whirlpool builtin microwave humkming loudly
yes for sure magnetron or diode has gone bad.but usually it is the mag.magnetron when go bad they start making noise and stop heating.when chaging magnetron chg the diode with it.
Anonymous
  • 534 Answers
  • Posted on Jul 16, 2009
SOURCE: GE Microwave making loud humming noise
humming sound is your magneto going out Dont have any idea of the cost for replacement however it may be cheaper to purchase another microwave than to repair this one. Good Luck
Dave
A sound like hooter comes after few second during microwave cooking. what is the problem.
If your microwave is making an unusual or loud humming noise, you may have a problem with the magnetron. This component is part of the high voltage circuit and provides the microwaves that generate the heat. If the magnetron is defective, it may cause a loud humming or buzzing noise
Microwave is making a noise
If your microwave is making an unusual or loud humming noise, you may have a problem with the magnetron. This component is part of the high voltage circuit and provides the microwaves that generate the heat. If the magnetron is defective, it may cause a loud humming or buzzing noise.
https://www.fix.com/repair/appliance/microwave/unusual-noise/
No heat in microwave. Makes loud humming sound when turn on. Model GE Spacemaker JVM166OWBC 04
The humming can be caused by a couple of bad parts. Usually it's the magnetron tube, the microwave source. They often fail by shorting out, and the loud hum from the power supply is what you hear. Another part called the HV diode may also have shorted, but the magnetron is more common.
A bad magnetron can be replaced, but it's a costly part. And microwave service should be left to a professional, because there are dangerous voltages under the cover and a chance of microwave leakage if repairs aren't done correctly. Between the part and labor costs, it might be more economical to replace the oven. Let a qualified servicer give you a repair estimate and then decide.
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
3helpful
The unit is 3 years old and when I turn it on there is a loud hum. Theunit also does not heat but turns the turntable?
From your description it sounds like the magnetron has failed in this oven. That's the part the makes the microwaves to heat the food. It typically fails by shorting out and making a loud hum noise. It not usually worth fixing since the price of a replacement magnetron is almost as much as a new oven.
3helpful
Dave
2helpful
Loud humming noise
If all of your door switches check out, replace the magnatron, capacitor, and diodes.
3answers
Loud humming/no heating
Word has it that many of these models have a defect which causes the microwave energy to be reflected back to the magnetron, causing damage to the magnetron, and eventually damaging the high-voltage diode too. Also, the fuse or the magnetron theral cutout / thermostat can eventually blow, too. There is a replacement magnetron and stirrer kit available. I would definitely call the GE Answer Center at 800-626-2005 about this. It's not considered a recall, but a "campaign". They may pick up part of the cost. It's not cheap.
Top Electrolux Microwave Ovens Experts
Paul Bade
Jerry Naidoo
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
