I turned off the water line to the automatic ice maker, but that didn't do any good.
the water is leaking inside the frig. it pools up down below the veggie & fruit trays
You probably have a clogged defrost drain. When the unit goes into defrost, the melt water is intended to go down a tube from your freezer down to the bottom to a pan. if the path from the freezer gets clogged, the water will seek its own level, and drip into the refrigerator. the short quick temporary fix is to unplug the unit and open both doors, blow fan for 24 hours. You will eventually need to have this serviced by an expert refrigerator repair service, it shouldnt cost more than $150, but if you attempt on your own, you could cause expensive damage, possibly forcing yourself to buy a new refrigerator.
