Hey Guys,
So here is my issue. It will not start it's cycle. It sounds like it starts to run the water but at the point where the water supply runs into the a plastic housing with some electrical coming into it it makes a sound reminiscent of a dry squeegee going across a window and then stops trying to use the water. I tested the draining and it is fine. Any suggestions. It seems like the spot where the noise is coming from is the electronic control valve.
Thanks a ton for any help.
SOURCE: Bosch Dishwasher
carry out a reset.
This should reset the board back to factory settings,
Deep Diver
SOURCE: Pump Runs On After Water Is All Drained Out?
If the cycle does not stop draining that is usually because of a faulty
water level switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Check if the floating sensor is stuck or faulty.
Some machine may use a membrane switch instead of a floater.
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
SOURCE: Bosch dishwasher shu43c - no water is getting in.
The problem is in my free guide. It is here. Odds are the drain line is plugged and it isn't letting in water because the old water isn't being pumped out.
SOURCE: Bosch shu4006uc dishwasher timer problem
REPLACE YOUR MODULE. IM A OLD BOSCH TECH. POST 4 THUMBS FOR THE INFO THANKS
