Cars & Trucks Logo
Posted on Apr 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1998 Lexus gs300 at idle Very loud buzzing type noise from engine
While at idle and in gear a very loud buzzing noise all of a sudden from left side of engine ares, at the same time brake light on dash came on, stepped on brake pedal and light goes out for a second then reappears, pedal feels wierd , problem lasted about 30 second then stopped making loud buzzing noise and everything was normal again
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Apr 09, 2010
Anonymous
Expert
Level 2:
Answers
52
Questions
Helped
18216
Points
132
Check brake fluid level.
master cylinder might be of interest, but i would check the fluid level first
1998 lexus gs300 code p0155
P0155 O2 Sensor Heater Circuit Malfunction (B2S1)
bank 2 ...side one
either the 02 sensor has failed or getting too much voltage
go with replace 02 sensor first
Where is the fuse box on a 1998 lexus gs300?
On this website you find fuse box diagram and description for Lexus GS300 (1998 - 2000)
Lexus GS300 1998 2000 fuse box diagram Auto Genius
My lexus gs300 will start but will not stay crunck unless the air is on and when you drive it with the air on it makes a loud noise. What is this?
WHen you turn on the a/c, the computer kciks up the idle speed to compensate for th load of the compressor on the engine. That tells me your idle air control is not wrking electrically or hte passages are plugged.
Where on a 1999 Lexus GS300 is the Fuse box diagram
7helpful
Buzz noise behind dashboard 2001 GS300 LEXUS
The buzz noise is probably coming from the airflow controls turned off but being stuck in a particular mode such as vents and feet mode or winshield and feet mode, creating a buzzing noise while it is turned off. To stop the buzzing noise turn off the aircondition / heat by pressing the off button, next press the mode button for the fan controls to make the picture point to face only not feet or winshield, this should stop the noise.
7helpful
1999 gs300 shows code p1349 and the engine runs really rough at idle , runs fine off idle
Its a Oil Control Valve most likely. Get the valve. Its like 100 from Lexus. Mine did the exact same thing with that code. GS300
98 gs300 loud screeching noise that last for about 5-10 seconds
The only four rotating items under the hood are
engine
power steering pump
A/C compressor
and smog emission pump.
==== I would check the fluid level on the power steering first. Check for pink fluid leak on the ground,
==== Check the A/C system with the wheel turn to one side and APPLY ALL LOADS.
Example: high beam on,A/C max,radio on and deforster on.
This will give you system a stress test.
All eyes on the pully and locate to part that generate the loud screeching noise.
My bet is on the power steering pump.
Please post more info on the comment window.
I will follow up on it.
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Lexus Expert? Answer questions, earn points and help others
