Kitchen Ranges Logo
Posted on Feb 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
3 of 4 heating elements on Kenmore glass cooktop do not heat properly. They come on and then cycle off and on and never reach a cooking temperature. Only one of the 4 works properly. I believe the model number is 665.95012 or 665.92012. Both numbers are listed on the manual.
L Vincent Testa
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Kenmore Master 724 Answers
  • Posted on Feb 26, 2018
L Vincent Testa
Kenmore Master
Level 3:
Renaissance:
Answers
724
Questions
0
Helped
367219
Points
3088
This might be normal behavior is the unit still heating and boiling items? has the unit worked differently in the past?
see below
Why the smoothtop radiant cooktop element cycles on and off
  1. Save as PDF
  2. Share
Table of contents
Does the radiant heating element cycle on and off?
  • The surface cooking area may glow red when a heating element is ON.
  • Some parts of the surface cooking area may not glow red when a heating element is ON.
  • The warming zone element (on certain models) will not glow red.
  • Radiant elements have a limiter that allows the element to cycle ON and OFF, even at the HI setting, to prevent damage to the ceramic cooktop. This is normal operation.
  • The radiant heating element retains enough heat when off to provide a uniform and consistent heat. The surface will still be hot even though the element has cycled OFF.
  • Cycling at the HI setting is normal and can occu
3 Related Answers
IFIXALL
Archie Ferrarini
  • 869 Answers
  • Posted on Jun 07, 2008
SOURCE: Replacing Glass Cooktop on GE JPB82
1st....You have to pull out the cook top first.2nd...remove the 1/4 inch screws that hold the top down(they are mounted on the side os cook top ) ,you dont remove the lowest ones.remove the burners from the top and your there :) Please Rate This !
Anonymous
  • 242 Answers
  • Posted on Dec 30, 2008
SOURCE: Glass cook top has cracked ...
They are expensive but not very hard to change if your carefull. They are about 300-400 on the norm , You may be able to get a new oven on sale for that much ,its up to you. Check with sears parts first. good luck
Anonymous
  • 1136 Answers
  • Posted on May 17, 2009
SOURCE: How to replace radiant heat element
HI, on most models, there are three to four screws that hold the top to the cabinet. Look at the flange above the door to locate them. If this is the right nodel, the top should just raise up after the screws are removed. Be very careful not to twist or drop the top after it has been raised.
I hope this helps
Vic
Cook top not heating up unless i put it on high
It's probably the control. Some of them have little heaters in them that heat up a bi-metal which cycles the element off and on to get infinite heat control. That's usually the problem. The last one I replaced cost about $20.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
tip
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
CERAMIC GLASS CHARACTERISTICS:
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
PROPER COOKWARE:
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
COOKWARE CHARACTERISTICS:
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
CLEANING and CARE:
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 • Cooktops
Someone heated a wet pan on my radiant cook top range and now the burner doesn't work
don't think this is related. the heating element is under to glass cooktop. water cannot get to it.
1helpful
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
I replaced what I thought was a bad 9" heating element on my Kenmore glass top stove and the new element still does not work or even attempt to come on. what should I do next?
Did you check if electricity was coming to the element. Try putting a volt meter on the two wires and turn it on see if you get anything...could be a bad switch
Firgidaire electric glass cook top- One of the large burners will heat up with the switch in the off position. Is this likely a switch problem? Thanks
Yes. Usually when the switch is bad, it will basically become in the closed position all of the time. Therefore, your element will heat up without the switch o
Can I cook on a cracked cooktop
The glass cook tops are made of tempered glass. Even small crack can eventually lead to shattering if the glass if heated in a condition where it has a weakness. In addition, depending on the severity of the crack, any liquids that boil over while cooking can end up directly on the heating elements. This could lead to catastrophic failure of the elements and/or an electrical shock hazard. It is strongly recommended that the cooktop is replaced as soon as possible.
If you need guidance on how to replace a cooktop, the following link explains:
http://www.fixya.com/support/r4249512-replacing_glass_cook_top
Repacement parts can generally be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare. The first three sites include helpful exploded view parts illustrations to assist you with locating and properly identifuing any parts you may need.
I found the following part number(s) : WB62T10475, WB62T10476, WB62T10477
The correct part number and price will depend on your COMPLETE MODEL NUMBER and COLOR of your range.
If you have any further questions, please post back and let me know. I hope this helps you.
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
New whirlpool range (smooth top) burners cycle on and off. Example.. turn on, 23 sec, off 28 sec, on 12 sec, on 11 sec off 30 sec, on 14 sec, etc. Impossible to cook properly
ok
i have been called out alot on this,,,,
believe it or not thats 100% normal
you are not cooking with those burners, you are actually cooking from the heat of the glass.
your "burner" element will cycle as needed to keep the glass your pan is sitting on at the temp you set
let it heat up, the glass will get hot quickly, GAS FAST as they say....
dont worry about the cycling put your pan on top and begin to cook,, it will work
My Kenmore cooktop will not heat properly, all 4 burners. They turn on and heat a little bit, but the burner on lights do not light up and the burners do not heat to full temperature. I closed my oven...
hi my name is mark, a service tech needs to check the voltage to the cook top. you will probably find improper voltage. check data plate for proper voltage should be 208v or 230v depending onwhere you live.
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
