Televison & Video Logo
Posted on Mar 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phillips 28PW6006/05-Locked we have owned this tv for approximately 5years the model number is Phillips 28PW6006/05and for no reason it shows Locked on the screen can you please help as our remote control is broken and we are unable to get the tv to work
Anonymous
Level 2:
Scholar:
  • Expert 104 Answers
  • Posted on Mar 18, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
33254
Points
260
First you need to get your remote working, without it you cannot unlock the tv. If the romote is not phisically broken (or smashed) make sure the battery contacts are clean and install new batteries.
Once you get the remote working (hopefully) Enter the MENU and select 'Features'. Set the Child Lock to OFF. If you cannot get the remote to work try a universal remote, setting it up with the codes for your tv provided in the setup manual for the universal remote.
2helpful
When i turn on my TV (Philips) it's shows black screen and in middle is writed Locked after 7-10sec it turns off
That's a fairly old TV...The locked means that specific circuitry is locked because if running it would cause a major problem, and that is also why it shuts off. You are going to have to find someone familiar with Phillips TV's.
Phillips 42PFP53320 42" Plasma TV. No picture,
Hello jporter...
welcome here in fixya..
That problem is one of the common problems of plasma TV (have sounds but no picture)..As a expert of flat panel for more than 5 years I already encounter that kind of problem many times..
Actually that problem is caused of either X,Y or Z sustain board or even both 3 boards are faulty..Because some models when the one of those boards have short circuit or bad there are possibility that other sustain board are affected..But most the problem like yours is "Y-SUSTAIN" board..
I can't find your model online please double check it it either Phillips 42PFP5332D/37 or 42PFP5532D/05
And for specific and easy way to find replacement please try to look at the part # of that board (it is usually printed on the sticker attach to the board itself..
Hope it helps and please don't forget to rate my answer..
Have a nice day!!!
regards,
Chester.
What is the remote code for Dynex 15" HD TV
Dynex TVs can have different remote codes, depending on the model of the TV you own and the type of remote you are using. You didn't specify your specific Dynex model number, however the company only makes one 15" HD TV model. It's therefore quite likely that you own model DX-15L150A11. Even if that isn't the exact model you own, the information below should apply to all 15", 19", and 22" Dynex TV models.
Below is a list of the most common remotes, along with the corresponding IR remote code for your TV.
CableVision UR2-CBL-CV04 code: 096
Charter DIGITAL code: 0463
Comcast M1057 code: 0463, 10463
Cox COX code: 0463
Direct TV RC23 code: 10463
Dish Network VIP508 code: 720
Dish Network VIP622 code: 720
Motorola DRC800 code: 0463
One for All URC-6690 code: 0464
Phillips PDVR8 code: 115
Phillips PH5DSS code: 115
Phillips PHDVD5 code: 115
Phillips PMDVR8 code: 115
RCA RCU807 code: 135
Rogers DCT3250 code: 0463
Shaw DCT3416 code: 0463
Sony RM-VL600 code: 8043
TiVo HD code: 0091
TiVo SERIES 3 code: 0091
For more information, you can visit your TV's remote code information page by clicking here, then clicking on the "Support/Downloads" tab.
Let me know if you need more information or have any other questions!
Sincerely, Ben
Phillips flat panel hdmi locked. all other inputs are good.
got to manufacturer website find your model tv download manual from there
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
When Turned on the Screen says ''Locked''
Please post the model of your TV. 0711 is a default code to access the blocking menu items on some Phillips TVs. have you tried changing the channel. maybe it's just the one channel is blocked. More likely the TV may be in a blocked mode. If you have the manual there should be instructions to reset the blocked mode. There are manuals online. Use Google or any other search and type in your model number and "manual."
62 inch phillips Tv all of a sudden has a double image. The screen is showing the picture it looks as if it's in 3D but every chanel.
Please respond to this same post with the model number of your phillips and I will post what you need to repair the set.
2answers
My DVD player Phillips dvp 5150 show a region error when i try to play DVD.
I have a a Phillips DVD player with the model number DVP 5150. when i tried to insert a CD in the player, it doesn't show the loading screen in TV. My TV ios of samsung, Please help..
Picture color - it is a blue and green picture- no other color- looks artificial
update your tv with a usb drive. worked on my phillips 60PP9200D/37. get update at phillips web site. solves many problems
5helpful
2answers
Phillips Home Theatre System
to play discs from different regions on HTS3548:
Before you begin, ensure you have connected your DVD player to your TV and both have the power on. Once you have connected the TV, follow the instructions below.
-- Open the disc tray
-- On the remote control, press in sequence:
Disc Menu
Stop
7 3 4 4 6 6 0
OK
-- Make sure Region 0 is showing on the TV.
This should hopefully help!!!!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
