Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
customer reset or obvious fixes..contact the manufacturer for service..
measurement.
Error Codes
My E3 error turned out to be because I was pulling the strap too tight. When I tried again with the relcro strap loosened slightly, it worked perfectly. :-). Thanks for the info on what each code means. It helped a lot.
SOURCE: Walgreens digiital blood pressure monitor model
Since that BP Monitor has a 5 year warranty. Your best bet is to contact HoMedics (the manufacturer) Customer Support @ 800-456-3342. That's assuming you replaced the old batteries with new one's out of a in date package and all are placed properly.
Testimonial: "Thank You I think we might need a new one, over 5 years old."
