HP OfficeJet 6110 All-In-One InkJet Printer Logo
Posted on Apr 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
6110xi leaves a dark line on the right 1/3 side of the printed page. It usually looks like just a pressure impression mid print and sometimes leaves other 1/2 spaced ink smears on the borders. The problem is more pronounced when printing on photo paper. I have run alignment pages and it still shows, even on copy paper.
  • 1 more comment
  • Troy Staley
    Troy Staley Jan 13, 2018
    if it is a scanned page, look for a drop or dot on the scanner glass. this will come out as a line on the page. if not, you've got a little lump in the wiper on the transfer ribbon or on one of the toner wiper arms. blow them oout with some compressed air and try again.
  • Troy Staley
    oh, don't expose the drums to light any more than necessary. and never direct sunlight while doing this. the transfer ribbon is not sensitive to light so don't worry about it.
  • Troy Staley
    this is a laser printer and does not use ink. I didn't check the model to confirm this but by the pic it looks like a laser, not a inkjet
Anonymous
Level 2:
Novelist:
  • Expert 91 Answers
  • Posted on Apr 07, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
91
Questions
0
Helped
59462
Points
218
Print is skewed
  1. The rear access door might not be fully locked into place, causing the paper to skew in the all-in-one. Remove the rear access door by pushing in on both release tabs as shown in the figure below. Inspect it for damage, and then reinsert it. Make sure it is securely latched in place. Figure 6: Releasing the rear access door latch on one side6110xi leaves a dark line on the right 1/3 side of - c00222462.jpg Figure 7: The rear access door remo6110xi leaves a dark line on the right 1/3 side of - c00222463.jpgrc="/uploads/images/c00222463.jpg" alt="c00222463.jpg" class="h_mi" />
  2. The paper feed rollers may be dirty. Over time, paper fibers and dust will stick to the rollers and should be removed.
    1. Unplug the power cord from the back of the all-in-one and open the front to expose the print mechanism.
    2. Gently wipe the paper feed rollers with a soft clean cloth slightly dampened with clean water. These rollers may be rotated with the power unplugged.
    3. Remove the rear access door shown in the figure above and wipe the paper supply feed rollers. These rollers may be rotated with the power unplugged. Allow the water to dry for five minutes before reinserting the rear access door and locking it in place.
    4. Close the all-in-one and reinsert the power cord.
Anonymous
Level 3:
An expert that gotĀ 20 achievements.
An expert that gotĀ 10 achievements.
  • Master 1,768 Answers
Anonymous
Master
Level 3:
Answers
1768
Questions
0
Helped
528603
Points
5915
This is the result of a dirty printer head and needs to be cleaned manually with denatured alcohol or print head cleaner.
There is a piece of paper or fiber that has lodge in the print track of printer and it has ink on it and then leaves a reference on the printed page.
How to reset counter workcentre 6505dn?
Try this link:
Read the Billing Meter The total number of printed pages can be reviewed at the Printer Control Panel, on the Configuration Page, and in CentreWare Internet Services (CWIS).
Three meters are available:
  • Total Impressions
  • Color Impressions
  • Black Impressions
The billing meter counts the number of pages that were printed properly.
  • 1-sided prints, including N-up, are counted as one impression.
  • 2-sided prints, including N-up, are counted as two.
    NOTE: During 2-sided printing, if an error occurs after one side is printed properly, it is counted as one.
  • Color documents converted using an ICC profile on applications with the Color (Auto) setting can print in color, even if displayed in black and white. The data prints in color even if it seems to be black and white data on the Display Screen. In that case, the number of Color Impressions is increased.
    NOTE: Grayscale images printed with the composite black setting count as color pages because color consumables are used. Composite black is the default setting on most printers.
  • When printing automatic 2-sided printing, a blank page can be inserted automatically depending on the settings in the application. In this case, the blank page is counted as one page.
View the Billing Meters:
IMPORTANT: The Bill Meters track the total number of pages printed for the life of the printer; it cannot be reset.
To view the total number of pages printed:
  1. Press the [System] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until "Billing Meters" is selected, and then press the [OK] button. The Print Volume Report will be printed.
  3. Press the [Down] arrow button to scroll to the required meter. The number of printed pages is displayed below the name.
  4. Press the [Return] button to exit the Billing Meters menu.
http://wss.support.xerox.com/GTConnect/UnifiedAcceptor/AddWebFramework.Main/site/XeroxProductSupport/product/product_wc6505/lang/en-US/region/region_US/source/DND/Xlang/en_US/Xcntry/USA/prodID/WC6505/KBlang/en/#!view-content/ViewContent/View/contentId/x_6130_en-O8884
Printer prints off left side of page
You're Registration is off. This is an adjustment that must be done in the Diagnostic mode of the printer. You're better off getting an actual tech who knows how to make this adjustment. You can move the image left/right and top/bottom. Can mess things up bad if you don't know what you're doing.
2answers
Dark print out
check the fuser... to see if one of the rollers has toner all over it... then check your paper path... to see if you see any obvious signs... then try printing 20 pages and opening the copier at various times during the printout process... you want to see if you can catch it where the dark starts appearing... chances are where it starts... is right next to the bad part... you are looking for a print out with one half no dark and the other half real dark...
Iā€™m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
2helpful
Dark line is printed on the right side of every
Most likely this is the drum. Take a damp cloth and clean the top of the drum roller. This should fix the problem. Good Luck.
1helpful
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
2helpful
Typewriter is not printing dark enough. Is there
Many SCM typewriters have an impression control knob on them. Look for a knob on either the right or left side of the the keyboard with numbers from 1 to 10. The higher the number reading the darker it is supposed to print. Be careful not to go so high that the typeface cut holes in the paper. If this doesn't help, try putting a drop or two of sewing machine oil (or Triflow Oil) on your finger and rubbing it across the typebar segment (the slotted and curved metal piece that the typebars pivot in). Since the typewriter sat a while the segment may be sticky. Hope this helps.
Vertical lines printed on right side of every page
Would be helpful to know the brand and model of the printer. Sometimes this is caused by not returning the slide used to clean the primary corona wire to its original position (usually to the extreme left side of the toner cartridge) after cleaning the corona wire. If you haven't cleaned the corona wire, you should follow instructions and do that first.
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
PRINTING IS DARK
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
2answers
Improving print quality
pls specify make and model
k24674
Grand Canyon Tech
Grand Canyon Tech
