Hi have you checked you cigarete lighter is working in the car if you still have the in car lighter then put this back into the holder and press it down as if you are going to use it then switch the ignition on and wait to see if the lighter pops up if it does check its hot if its not hot or dont pop up then the chances are you have blown a fuse so check all the fuses in the fuse box and replace any that are blown, if how ever it does pop up and does get hot then this would point towards a fault with the lead your using to charge the tomtom so replacing this will then solve your problem
