Maytag MZD2766GES Side by Side Refrigerator Logo
Posted on Apr 07, 2010
Slowly stopped cooling over the past 30 days - Maytag MZD2766GES Side by Side Refrigerator
Anonymous
Level 1:
  • Contributor 316 Answers
  • Posted on Apr 07, 2010
Anonymous
Contributor
Level 1:
Answers
316
Questions
0
Helped
106078
Points
21
You dont give any detail at all, so my best guess is you have a sealed system leak of refrigerant. This is NOT something you can repair yourself, only an EPA Certified Refrigerator Repair service can perform these types of repairs. Its possible it might be something else, I am just guessing after all, i would have a qualified refrigerator repair service inspect and diagnose your fridge.
Fan and compressor running but fridge not cooling
Your defrozed cycle seems to be not working. Means there can be problem with heater , timer or defrzed board or defrozed thermostat. You have to open panel from coil to diagnosed this.
I have a Kitchenaid refrigerator model kbra22klss01.
Try turning the=> 8170840 Defrost Timer clockwise slowly. It may be stuck in the defrost lobe and the timer is so weak it cannot turn to get out of defrost,. Sea Breeze
Freezer needs to be defrosted every 3 to 4 days
Let's Try turning the defrost timer clockwise slowly. 67001036 Defrost Timer The defrost timer is item location 12 in this photo HERE and there should be a hole with a plastic plug covering the hole that you place the screwdriver through. Turn timer with a flat head screwdriver slowly until the compressor and fans stop. With fans and compressor stopped for up to 30 minutes the defrost heater should come on. If doing this causes the defrost to take place simply replace the defrost timer. If not then please let me know and I will instruct you on how to change the=> 67001794 Defrost Heater Assembly and the 12001937 Defrost Thermostat Thanks Sea Breeze
Our A/c doesnot hold the tempeture set. If I set it for 78 as the day gets hotter it slowly climbs to up to 81. It will eventualy come back down to 78 after a hard day of work. If there is rainy day it...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
1helpful
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
1993 Volv0 940 intermittent starting problem
Sounds like your fuel pump relay,replace this first.
1helpful
Kemore Refrigerator MODEL# 2535808789A is not cooling.
Thank You for having your model number ready, Could you remove the grate on front and bottom of refrigerator to expose the defrost timer. In the opening on front turn the timer slowly turn clockwise until you hear a click or change in operation of refrigerator. Let me know, Sea Breeze
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
