If the following instructions don't work and you have a good battery the keypad has failed.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Testimonial: "Bless you....thanks so much... its working, yea."
Can't get the key less entry to work. Chamberlain replaced the keyless entry and now it works without any code
SOURCE: How to reprogram Sears Mult-Function Keyless Entry garage opener
hit learn button for 2 seconds, enter 4 digit code on keypad and hit enter. light bulb blinks 2x. for remote, hit same learna and hit remote button.
SOURCE: Isn't there an 800 number for assistance
How about I tell you how to program it.
On the rear of your motor unit near where all those white wires go you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in any 4 digit PIN you like and press enter.
If you have the correct keypad for your opener you should be set.
SOURCE: How can I reprogram my keyless pad?
If you mean wireless keypad it is like this. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
SOURCE: can a craftsman 953876 keyless entry pad garage
If both units were manufactured before April 2005 or both were manufactured after that date they should work. If one is older and the other newer than that date they will not work with each other.
SOURCE: My lift master security plus keyless entry pad for...
You can try programming it but first make sure the battery is good. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
