Where is the reset on hp r707 digital camera
There is no reset button on this camera. For reseting it follow these steps (from the MANUAL, page 122):
1 In the Setup Menu , select Reset Settings....
2 In the Reset All Settings? sub-menu, highlight one of these
two choices:
? Cancel ? Exits the menu without resetting any of the
settings.
? Yes ? Resets all camera settings to their default value in
the Capture Menu and Setup Menu (except Date & Time,
Language, TV Configuration, and USB Configuration).
3 Press Menu/OK to reset settings and return to the Setup Menu.
SOURCE: R707 Fails diagnostic test 10 (strobe)
I found my answer to this on another board. Remove the battery and SD card. Use a paperclip to press in the small siver dot above the + sign for about 10 seconds. This resets the firmware. It worked for me, hopefully it will work for you too.
