How to modify ps2fat without modchip
SOURCE: How to Install PS2 Modchip?
what you need: an IDE harddrive (maxtor or seagate works best. ive got a maxtor diamondback or whatever its called), the online adaptor and hdloader. hdloader can only be found on the internet so google it. if youre interested in my setup then you need the original hdloader then you can go to ps2hd.com and find all the other programs if youre interested in doing cogswap (play burned games without a chip) then also search that site for the ps2 exploit disc and cogswap. each harddrive is different and can require differnt jumper settings. look on your harddrive to figue out what is cs or check te company's website where you put your harddrive on the ide cable matters. when i first installed a secondary harddrive in my computer i had to shift my original harddrive down one position to make room for the secondary and allow it to take the secondary position on the ide cable. if you switch them then your computer will tell you "cannot find primary harddrive" and will not boot. one thing that i didnt mention is that you should also ground yourself after grounding the computer. your body can carry static electricity and if it gets discharged inside of your computer you can destroy components like RAM, the motherboard or even harddrives. to ground yourself touch a part of the metal casing of your computer. this will continue to be updated as i find more things that i forgot to say
SOURCE: ps2 mod chip
i'm indian too but i live in usa i'm having the same problem but if i'm not able to find the chip in america than we should just forget about playing pirated games or whatever even though i don't have any pirated games
SOURCE: PS2 Version 10 Modchip Installation Request
Which solution are you looking for, there is the PS1 independance exploit that boots the file from memory card or the new freemem option which launches automatically as well as plays backups, etc. I live in NV
SOURCE: how can i modify my ps2 scph-30001
go to you tube and it shows u how to or go to e starland .com and buy magic 3 ps2 moder (its a dvd)
