My nokia phone N70 can not access my memory card, the battery get flat quick while my memory card is inserted into the memory space it keep telling me NO MEMORY CARD INSERTED,
remove the sim, battery, and memory card then clean your sim with eraser then try it on. if problem continues try a new sim and if not work again no other solution but to consult a technician.
This means that you need to free up some space in you phone memory or memory card. Access the file manager from the menu and start deleting some of your files there that you dont use anymore. Files would be pictures, sounds or video. This will solved the issue once you free up some space.
Dont do any more harm but to spoil the set , I advice that you can take the set for review to a Nokia service center.
You can remove battery and keep aside, remove the memory card.
Now set the battery in after and hour. If this works allow it to load then insert the memory card.
If not get the set checked for hardware./software issues.
first connect your memory card to a card reader and check wehther it is recognising...if no,sorry to tell you this, your memory card is currupted. formating is the only one way to get bak your memory card...hope this will helps you...thank you...
take the memory card out of the phone and then try all of the options
to reset to factory defaults etc and if it is related to the memory
card it will just give you an error message of some description to
state that it cant erase the memory card because you do not have one
1 remove the memory card form set . 2 . use the memory card adapter and insert that in some desktop or laptop and after u see that u will be able to acccess it in system . 3. if u still find the problm as system cannot access the data search this in google "file copy software named 'bad copy' then access using that "
if problm still presist mail me with message tag as FIXYA
Hi
your phone is slow because probably you have memory card over 1GB capacity and it`s full оr problem with the software or the programs you instal on your phone.
