The control module has be changed. you can go to thermador .com you can order it from them
Bosch Guru,
Is this a common issue with the Bosch SHE46? I have the same issue now and want to try to fix on my own, but want to problem solve with initial steps first before spending a few hundred on the control module. Any other tips? I couldn't figure out the test cycle for the SHE46 and Bosch was no help. Is it the same as for other models...press power scrub and regular, and depress power button? And then what are the error codes for my model? Thanks very much in advance!
I had same problem I just soldered relay cold solder joint all good. Hope it lasts!
could b slow water fill? check little filter at tap end of inlet hose. check how fast it is draining.could b blocked where drain hose meets sink drain pipe.also check how fast water is coming out of tap.
I now have the exact same problem with the exact same model Bosch dishwasher. What solved your problem...did you have the control module replaced or was it another issue? What was the cost, and is this something a fairly handy homeowner could fix?
