Print keeps fading, (and breaking up a bit) even though using new ink cartriges. Appears to be the black print thats the main problem as fades to a much lighter redish / pink colour when printing black text ?
Check your printer settings, make sure color only is not checked off, or if you mainly print black and white documents, you should have that option checked, you may have to go into advance printer options to do this.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
Select Print from the File menu. A Print window appears.
Make sure EPSON Stylus CX9400Fax Series is selected.
Click the Preferences or Properties button. (If you see a Setup, Printer, or Options button, click it. Then click Preferences or Properties on the next screen.)
A printer properties or preferences window appears.
Select the type of document you're printing for the Quality Option setting.
If you want to print borderless photos, click the Borderless checkbox.
Make sure you've selected the paper type and size you're using for the Type and Size settings in the Paper Options section.
Click the Advanced button. The Basic settings change to the Advanced settings.
Make sure the High Speed option is not selected in the Print Options section.
Make sure the Black Ink Only option is not selected in the Print Options section if you're printing a color or black and white photograph.
Select ICM in the Color Management section if you're trying to precisely match on-screen colors.
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Try cleaning the head of the cartrige with alcohol and a Q-tip, if this doesn't help you may have to buy a new one. Cartriges can dry up if they haven't been used for a while. Even though you refilled it, there could be some dry ink stuck in the head. Hold the Qtip with alcohol on the head for a bit and let it dry, reinstall it and then try printing again.
