My 2wire modem keeps on shutting down and keeps coming on on its own. Sometime it works fine for hours but sometime it will keep switching off and on very frequently.
Sometime the modem will show that it is working fine and even in the laptop it will show the strong signal of wireless and will show that it is connected to internet, but internet does not work.
SOURCE: 2wire 2700 not connecting to internet
Make sure you have DSL filters installed contact me if you need any help
SOURCE: 2wire modem/router keeps rebooting
ANOTHER COMMON ISSUE: If your modem keeps restarting once the power LED turns solid green, the most likely cause is the power adaptor. Replace the power adaptor and all should be well again.
SOURCE: connect wireless linksys to 2wire modem
put the modem on bridge mode and set the pppoe on the lynksis router and that should get you going
SOURCE: CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
SOURCE: ATT 2wire modem will not work. Red light on power button.
its the power cord. the fail after a year to 1 1/2 yrs. get a new power cord
