Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Will not draw cold water - Frigidaire Gallery GLWS1339EC Top Load Washer
    President:
  • 2,468 Answers
Either the solenoid valve that controls the cold water intake is bad,the hose screen in the cold water hose is plugged or the hot/cold mix control isn't letting in cold water due to a voltage problem that sends power to the cold water solenoid valve to open it
Posted on Apr 06, 2010
Testimonial: "good advice to start my troubleshooting"
6ya staff
SOURCE:
Is a loud noise normal when drawing off hot water for tea?
not if it never did it before
when you draw off hot water , there is normally fresh water let in to keep the unit full
this cold water hitting the boiling water will produce steam which is allowed to escape hence the noise.
May 25, 2015 | Jura Impressa F50 Classic Automatic Coffee...
Maytag Atlantis Washer - no cold water
Check the solenoid valves. If it's connected to hard water, the minerals build up inside and won't let the internal plunger move.
Mar 16, 2017 | Maytag Atlantis MAV9501E Top Load Washer
Water stay in conditioner section of draw
Washing machine working fine conditioner being used but water always left in draw washing machine is cold fill only This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 24, 2012 | Hotpoint Aquarius WMA42 Front Load Washer
Model WPRB9220C draws cold water when it's supposed to draw hot.
Your hot water inlet solenoid has failed and needs replacing.
Mar 11, 2012 | GE WPRB9220C Top Load Washer
My reliance natural gas water heater overheats causing scalding water to come out of my faucets. I have had authorized service companies come out three times to replace and retrofit different controls and...
Information below is for tank-type electric or gas heater only.
There is a condition called stacking.
This might apply to your water heater or not.
Having authorized service people to your house 3 times suggests more complicated mix of problems.
Stacking is caused when there are repeated short draws of hot water.
As you know, each time any hot water is drawn out of faucet, cold water immediately enters bottom of tank through the dip tube. The dip tube is connected to cold water inlet and runs to bottom of tank.
So all cold water enters bottom of tank close to the gas water heater thermostat.
See illustration of dip tube, that also shows copper thermostat sticking into tank that is connected to gas valve.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
Let's say your water heater if fully heated and burner is off.
A short draw of hot water causes cold water to enter tank.
Another short draw. And then another short draw, each draw happens close to same time as other draws.
Water at top of tank is plenty hot, but bursts of cold water get near thermostat and cause thermostat to turn on burner.
Burner heats water and more hot water rises to top of tank. Water at top of tank becomes overheated each time stacking occurs.
Again, a stacking situation may not be the cause of your problem.
However, remember if single-handled faucet is opened straight upward, then that draws both hot and cold water. And cold water immediately enters tank.
Only when the single-handled faucet is lifted with the handle all the way to the right, does it draw only cold water. Even so, some single-handled faucets have bleed-over between hot and cold sides, so hot water is drawn anyway.
Another possibility is that the dip tube ends at or near thermostat, instead of going all the way to bottom of tank. The dip tube should go straight down from cold water inlet, but dip tubes are made of plastic, and some self-cleaning tanks have a curved dip tube or dip tube with perforations that create currents designed to stir sediments off bottom of tank (although this is not proven to be effective deterrent to sediment formation).
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 10, 2011 | RELIANCE ELECTRIC WATER HEATER
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
Water temperature from the water dispenser of our new refrigerator is equal to the environment temp.it is not cold at all.is it normal?the dispenser produces ice cubes but not cold water
You may not have filled the water reservoir when you hooked up the fridge. Run about 2 gallons of water through the dispenser. Then wait about 12 hours before you draw more water. This way the dispenser will fill and have time to cool down. It should stay cold after this.
Aug 29, 2009 | Samsung Refrigerators
Washing Mashine draw Wont Empty
check the screen on the valve where the hose connects to the washer, it may be clogged
Jul 07, 2009 | Washing Machines
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
213 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
