In most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme, see the user guide for more information. To turn on and enable the wireless device, do the following:
To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon will display.
Wireless device is turned off or disabled
The
power to the wireless network and Bluetooth devices is controlled by a
switch or button on most computers. It is possible to accidentally bump
the button and turn off the wireless service.
On
To
above the keyboard.
. Click Turn On
will display.
You can also try pressing the fn+ F2 keys simultaneously to enable the wireless device.
It sounds like your WiFi switch was somehow shut off.
The
On
To
above the keyboard.
. Click Turn On
will display.
Or you can try pressing the Fn and the F2 keys at the same time to enable your wireless adapter.
The power to the wireless network and
bluetooth devices is controlled by a switch or button on most computers.
It is possible to accidentally bump the button and turn off the
wireless service.
On
Some newer models use different a different color scheme.
To
above the keyboard.
. Click Turn On
will display.
wireless service.
On
To
above the keyboard.
. Click Turn On
will display.
1. Press wireless button. 2. left click the dialog box in the bottom
right corner it will prob say wireless disabled etc. 3. HP wireless
assist box should open if so its working and you should click on
properties. 4. check all unchecked boxes and press apply or ok etc.5
you should now see in the top right corner of the HP wireless assist box
an option to turn on wifi press it. 6. Try the wifi button it should work! If not sorry it did for me.
Description:
This package contains the driver for the Conexant High-Definition Audio or HD-Audio SmartAudio 221 Chip in the supported notebook models and operating systems.
Enhancements:
Fixes an issue that may occur with notebooks that shipped in India with FreeDOS installed and later installed a Microsoft Windows Vista Operating System, where the notebook may return a "blue screen" error or stop working when performing audio playback and hard drive data transfer simultaneously.
Please delete the sound card thru the device manager first, then install the driver
Window Vista- Go To Control Panel, then go to Mobile PC, then Window Mobility Center, then go to the top right of the mobility center and click on Turn Wireless On
