SOURCE: *#7370# hard reset code is not working in my nokia
On these devices you cannot apply the soft or hard reset codes, you can only revert them to the factory settings. Your only try would be reinstalling the firmware through Nokia Software Updater:
http://europe.nokia.com/support/download-software/device-software-update/news
SOURCE: how to hard reset nokia 5130
You can reset it using a soft or hard reset. The following instructions provide you with information on how to reset the Nokia 5130 using both methods.
The soft reset is often the better option if you are worried about losing data. There is a chance the soft reset will also default to the factory settings,
but there is a bigger chance that it will not. With a soft reset you
will enter in *#7380#. This tends to clear any pending errors and on
most phones it will help your phone work properly.
These codes work with all of the Nokia models including the 5130.
You may find other options do exist such as the power button while
pressing the space key and delete key, and caps/ shift button will also hard reset the phone.
It all depends on whether or not the *# keys work. Sometimes they won't work if the phone is in phone lock or key pad lock and you need to get it open first.
SOURCE: how do i get hard reset nokia 5130-5 code?
Try 12345. If it doesnt work then please post your imei in the comments section.
