I have 3 12inch jl audio subs hooked up to it with a 1000 watt monochannel amp thats also jl audio befoer i hookede up the subs the problem was already present what could be causing this now it doesnt turn on at all
A mono amp usually can handle only two 4 ohm subs. You see when you hook up two subs in parallel it drops the ohms too 2 ohms and 3 in parellal drops it to 1 ohms overheating the amp and cause power failure. Unless you bought a Mono amp thats 1ohm stable. But still I've seen cheap 1 ohm stable amps not last long. Also possible your subs are fried too check them with a multimeter and measure each sub ohms.
