I just figured what PO773 code is. It is the Torque converter lock up solenoid. The solenoid has 2 bolts that can be undone from the top of the car. The solenoid is located behind park neutral safety switch. The plug has a pink with black strip. This is A140E transmission. The problem with the vehicle was the Check engine was on and the RPM would not drop 300 RPM on the freeway at cruising speed. I only post this answer because the only thing I could find in the web was the lock up solenoid was on the valve body. Toyota calls this solenoid #3.
Where did you find the replacement solenoid? None of the local parts stores seem to offer this item. They only seem to offer the S1 or S2 solenoid. Even an internet search has not been able to locate one.
It is a grossly over priced dealer only part, like all factory replacement Toyota parts are. Not to mention they were at the to of the list last year for the most recorded customer complaints. Very poor engineering to say the least. Who was Numero ono? FORD!!!
P0773 Shift Solenoid E Electrical Malfunction resistance is out of spec as measured by PCM, replace the shift solenoid.
hi, i do have this problem with my car right now and the scanner told me shifter solenoid, but i have no idea where it exactly locate at. help me out please. thanks.
The shift solenoids are located inside the transmission.
PLEASE, MY CAR,TOYOTA SIENNA 2001 MODEL,HAVE A PROBLEM WHICH INDICATED THE FOLLOWING ON A CAR SCANNER[AUTO SCAN FDS-5200], FAULT 03,PEND 01; AND P0773; 01/04.THE CAR HAS REFUSED TO MOVE. CODE P0773 SAYS-SHIFT SOLENOID E CIRCUIT ELECTRICAL.PLEASE, HOW CAN I SOLVE THIS PROBLEM?
Sl solonoid is to the left of the kick down cable going into
top of transmission two 10 mm head bolts plugged on top of solonoid
