I have a model 435 Husky that had the same hard-to-start problem--warranty service replaced the carburetor and it seems to work ok now. The chain that continues to turn can be fixed by turning the idle-speed screw (not the H or L jet screws) CCW a small amount until it can be accelerated then dropped back to idle to quit driving the chain. Hope this helps!
1 - Do NOT loosen a spinning sharpened chain then operate unless you want to remove a few body parts. I like my parts! 2 - If the chain turns at idle the idle is to high, slow it down. 3. - Hard starting is most often caused by flooding. How old is the saw? are you following the start procedure in the OM? Reply below please.
the chain is to tight. next to the bar there is a screw that you can back off to get the chain a little loose but dont go to loose as the chain will fall off....good luck
