Three posible points for squeaking are. 1.)Around the front door seal. there is a gasket sealing the drum to the front load door. 2.) Worn belt that drives the drum from the motor. About 3 ft. in diameter. 3.) Rear bearing that the drum couples to in the back of the machine.
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
If
your dryer
is not drying
like it once did or if you just have not taken the time to give
yourself a clean
dryer
in a long time then you need to do that. At least once a year the
dryer
cleaning
should take place. Lint
build up
in the dryer
duct
is one of the main causes for your dryer to fail.
Here is the
rest of this tip about Dryer
Maintenance
heatman101
