CROWN CE1000- powers up fine, goes through fault protection testing fine, but unit clips and slips into fault protection (cycling) immediately after connected to a speaker.
Using brand new single pair 16-20 speaker line (3 ft long) with working 8ohm speaker (used 3 diff speakers that have been verified to work perfectly)
Both channels do this, before ever rolling gain up, right after connecting to speaker.
Any ideas where to start?
If ur output power amp is defective u will have that problem - meaning the moment u connect load across it it will go into circuit protection to limit/stop excessive output current. make sure the speaker terminals are connected to +/- output terminals. in bridge mode use only channel 1 and that too with 4 ohms speaker only otherwise amp will clip. considering all connections are okay if it still clips when speaker is connected, u have a faulty power amp section. this the way ur amp is designed
Testimonial: "APPRECIATE THE HELP"
I have a crown ce1000 when running on bridge mode channel 2 clips is it normal? I'm running two peaveys 118s
