SOURCE: 2004 Honda Element...the clutch pedal engaging at 50%
Hi:
You could have a problem with your pressure plate, but you need to check out your clutch master cylinder and slave cylinder too. Check the clutch master cylinder fluid reservoir, and make sure it is full. It is located on the back wall of the engine compartment, approx right in front of your clutch pedal. If it is low, or you notice any fluid leakage, you need to address what caused that. You can bleed the system too, but that won't repair the problem.
